shoe mount on HPX370
COW Forums : Panasonic Cameras
Philip Fass
on Oct 19, 2011 at 6:59:33 pm
Simple question, but still need answer.
I normally think of a shoe mount as being a slot, and you slide your shoe-equipped accessory into it. In this case, it seems like the opposite. Slots on either side of a small plate, but no way to slide in a shoe.
Are you supposed to take off the screws and reverse the plate, or add a shoe mount on top?
Thanks.
Chris Tompkins
Re: shoe mount on HPX370
on Oct 19, 2011 at 11:39:07 pm
There are few ways to go about it.
I took a shoe mount off an old palmcoder I had and mounted it on the 370. Yes, you take the screws out that come on it. Watch you don't strip, they are TIGHT!
I was shocked it didn't come with one.
Or you can use the threaded holes in the handle.
Chris Tompkins
Video Atlanta LLC
