Steady Cam and Tripod with or without image stablizer?
COW Forums : Panasonic Cameras
Thomas Agostino
on Oct 17, 2011 at 6:53:15 pm
Hi I was wondering if I should turn on the image stabilizer while the camera is mounted to a tripod or steadycam? I've heard the stabilizer will make the image shakier while on a tripod. Is this true and does this apply to the steady cam as well?
Thomas Agostino
Re: Steady Cam and Tripod with or without image stablizer?
on Oct 17, 2011 at 6:54:33 pm
By the way this is in reference to the Panasonic HVX 200
Fernando Mol
on Oct 17, 2011 at 8:49:16 pm
If you have a tripod, you don't need the stabilizer.
It will cause you trouble NOT when the camera is steady, but when you do a movement, like a tilt. The stabilizer will try to get your image steady when you start the movement, until it can't, so you'll get an ugly jump in your movement.
This will happen differently on different cameras. It depends on the velocity of the movement.
I don't know about steady cams, but it should be the same.
I hope this helps
Chris Tompkins
on Oct 18, 2011 at 11:51:08 am
Always turn it off when on sticks.
Turn it on for hand-held.
Chris Tompkins
Video Atlanta LLC
Thomas Agostino
on Oct 21, 2011 at 4:11:30 am
Thanks for this, I kept the Optical Image Stabilizer off. The footage came out fairly well.
Best,
Thomas
