Need P2, CCD, HD, Genlock/Smpte, & 4;2.2 in a Camcorder
COW Forums : Panasonic Cameras
Sherwood Ball
on Oct 13, 2011 at 8:42:41 am
CCD's because I need to shoot action variety show with whip pans
plus Green Screen.
Anyone have any suggestions for a small compact camera
that can do the above?
Need to buy two, plus a few INdieCams.
Thnx.
Steve Eisen
Re: Need P2, CCD, HD, Genlock/Smpte, & 4;2.2 in a Camcorder
on Oct 13, 2011 at 1:03:19 pm
If you ask on this forum, we will tell you the HPX-250 (AVC-Intra) or 170. In todays age, you are going to have to forget about the CCD vs CMOS. You always have the option of connecting a device such as the KiPro or KiPro Mini via HD-SDI if you want 10 bit ProRes for green screen.
Steve Eisen
Eisen Video Productions
Vice President
Chicago Final Cut Pro Users Group
Chris Tompkins
on Oct 13, 2011 at 8:10:48 pm
HPX170 is CCD
DVCPRO HD Format P2
1/3 CCD
Handheld
Chris Tompkins
Video Atlanta LLC
Kristiaan Boschman
on Jan 29, 2012 at 12:49:26 am
If you need 4.2.2 and timecode you can take the AG-HPX250 which uses Intraframe compression at 100 Mbit/sec; the AVCHG model HPX160 supports up to 4.2.0 unless you take the SDI output to an external recorder like the Samurai. No CCD however; but i.m.o the most recent generation of CMOS sensors is better.
