720p60 at 60 frames to 24p in timeline
COW Forums : Panasonic Cameras
Eric Olson
on Aug 12, 2011 at 2:59:18 am
Ok, a bit of confusion: I shot some butterflies with the hvx hoping to overcrank the camera and get some nice slo-mo shots. I didn't have a whole lot of time to RTFM and I set the record setting to 720p60 and the scene file frame rate to 60frames.
What would be the best way to convert this to a straight 24p footage so it plays in slow motion? (And I still don't understand why there are seemingly two places in the menu to choose the frame rate.)
Muchas Gracias,
Eric
Steve Eisen
Re: 720p60 at 60 frames to 24p in timeline
on Aug 12, 2011 at 5:14:18 am
Use Film Mode to overcrank.
Take your time and RTFM. You will learn a lot faster than asking questions on this forum.
With the footage you have now, bring that into your NLE and use speed control to slow it down. Keep your sequence setting at 720p60.
Steve Eisen
Eisen Video Productions
Vice President
Chicago Final Cut Pro Users Group
Eric Olson
on Aug 12, 2011 at 11:02:54 am
Wow, thanks for that totally condescending and unhelpful response.
I'm guessing that I can do something in Cinema Tools. Anyone?
Sean Warman
on Sep 9, 2011 at 7:42:22 pm
Hi Eric,
sorry for the late jump in.
interested in how the slowmo came out?
did you use cinema tools?
I do a lot of filming with skiing at 60fps for over cranking, and use cinema tools for slowing. that has been great. sometimes I need to slow down more and I am using twixtor.
Any thoughts?
Sean
Imagesandconcepts.com
Eric Olson
on Sep 11, 2011 at 12:02:51 pm
Hi Sean,
Yes, I successfully used cinema tools. Here's the video if you are interested in seeing the results:
I would have liked to see less blur in the butterflies wings when the butterflies take to the air. However, in order to capture that I probably would have needed to overcrank more than 60p or perhaps used a faster shutter?
Thanks for the tip on twixtor.
Eric
Sean Warman
on Sep 11, 2011 at 4:52:56 pm
Nice job
BTW I thought Steve's response was rude and uncalled for. Did you convert all the footage to 23.976 or did you drop some 59.94 fps footage directly into the 23.976 time line?
I am running some test time lines that mix, several frame rates, but always interested in what others are experiencing
Sean
