Panasonic LH1700WP Monitor
COW Forums : Panasonic Cameras
Nigel Thompson
on Aug 11, 2011 at 2:14:59 pm
Hey guys sorry for double posting about a Panasonic monitor here but i didn't know where else to post it.
Had to borrow a friends 1700WP LCD the other day and after using it for a few days i saw a 1 pixel blue vertical line come up in the middle of the screen.... All the way down. so i checked multiple sources making sure it was not the kona or the source that was bad ... its def.. the monitor.
Upon further investigation i realized some idiot turned the fan off and didn't put it back on. so i'm thinking it could be a heat issue since these monitors do run hot.
Mind you the line disappears when i turn the monitor off for a while and turn it back on.... so def. feel its a heat issue.
what do you guys think ?
High End, Production & Post Production
in the Caribbean
http://www.bistt.com
Nigel Thompson
Re: Panasonic LH1700WP Monitor
on Aug 12, 2011 at 6:46:08 pm
No Answers i guess
in the Caribbean
Matthew Romanis
on Aug 15, 2011 at 7:06:29 am
Based on the info provided, it sounds feasible.
Whether it's heat affecting the panel itself, or just the processing module, needs to be checked out.
