Which tripod would you choose?
COW Forums : Panasonic Cameras
Eric Olson
on May 11, 2011 at 7:46:33 pm
I'm trying to decide between these three tripods for my HVX200. If you had a $700-900 budget which would you pick? Or something else?
http://www.bhphotovideo.com/c/product/601879-REG/Sachtler_0372_0372_FSB_4_A...
http://www.bhphotovideo.com/c/product/683635-REG/Manfrotto_504HD_546GBK_504...
http://www.bhphotovideo.com/c/product/688719-REG/Libec_RS_250M_RS_250M_75mm...
Eric
Eric
Noah Kadner
Re: Which tripod would you choose?
on May 11, 2011 at 8:28:49 pm
Can't really go wrong with any of those to be honest- all solid. I'd probably rank them Sachtler-Manfrotto-Libec in order of very slight preference.
Noah
Unlock the secrets of 24p, HD and Final Cut Studio with Call Box Training. Featuring the Panasonic GH2 and Canon 7D.
Matthew Sonnenfeld
on May 14, 2011 at 4:02:44 am
I've got the 504HD for my HPX170 and I use it with a mattebox and a rail system. It really does hold the weight well. Manfrotto stepped up their game on this one. The FSB4 is a fine tripod and it is a Sachtler but at that level of tripod I don't think you're getting what really makes Sachtler great. Above that, the FSB4 only holds 8.8 pounds as compared to the 16.5 pounds that the 504HD can handle.
In the end, a tripod can seriously outlast your camera if you treat it well and you look ahead. If you ever decided to add weight to your rig or upgrade your camera, the 504HD will give you significantly greater flexibility over time.
Panasonic HPX170 P
2008 Unibody Macbook Pro 15 inch, 2.8 Ghz, 4GB RAM
CalDigit VR
Final Cut Pro Studio 3
Avid Media Composer
The College of WIlliam and Mary
Kevin Sio
on May 24, 2011 at 7:59:07 pm
Beware of ground level spreaders if you do work outside and/or on uneven ground. Much easier to set and level sticks with a mid-level spreader.
Kevin
Kevin Sio
Videographer/Editor
Corporate Affairs
National Grid
Eric Olson
on May 26, 2011 at 1:51:58 am
Just to follow up, I ultimately bought the Manfrotto 504HD head with the Libec RT30B legs. The ultimate frankenpod!
Cheers,
Eric
