HVX-200 auto audio level
COW Forums : Panasonic Cameras
Piotr Niemcewicz
on Apr 12, 2011 at 5:18:09 pm
auto audio level
how??
Noah Kadner
Re: HVX-200 auto audio level
on Apr 13, 2011 at 5:03:39 pm
Er sorry- it's not that kind of camera. Professional = non-auto audio.
Noah
Unlock the secrets of 24p, HD and Final Cut Studio with Call Box Training. Featuring the Panasonic GH2 and Canon 7D.
Frank Nolan
on Apr 14, 2011 at 7:27:17 am
[Noah Kadner] "Er sorry- it's not that kind of camera. Professional = non-auto audio."
Well that's not entirely true. There is a function called ALC (auto level control) in the recording set up menu which when set to on supposedly reduces distortion at high input levels, although it does say in the manual that it doesn't change the audio signal recording level.
Piotr Niemcewicz
on Apr 15, 2011 at 8:48:15 am
ALC is like limiter, not auto audo
Frank Nolan
on Apr 15, 2011 at 4:30:45 pm
Yes exactly, however when you are using the inputs 1 & 2 for external sources, the onboard stereo mic automatically gets routed to tracks 3 & 4 and if you have ALC on it does act as a control for the level of the onboard mic as there is no manual control in that situation.
Piotr Niemcewicz
on Apr 15, 2011 at 7:02:20 pm
yes, if you write in 4 audio track mode
only DVCPro 50, and HD modes
but if you work in DVCpro or DV or write on tape in DV mode (48 kHz)?
