P2 formatting
COW Forums : Panasonic Cameras
Dan Davis
P2 formatting
on Mar 28, 2011 at 2:04:38 pm
when I go to format one of my P2 cards with panasonic "P2 Formatter" software I get a error message. All my other cards format fine. Anyone else run into this or have any idea why this happens to only one of my cards? Thanks in advance.
Cheers,
Dan
Jeremy Garchow
Re: P2 formatting
on Mar 28, 2011 at 3:58:07 pm
Can you format the card in camera? Is the firmware up to date on the card?
Steve Eisen
Re: P2 formatting
on Mar 29, 2011 at 12:20:17 am
I don't get errors but sometimes it will crash on opening. A restart always solves the problem.
Steve Eisen
Eisen Video Productions
Vice President
Chicago Final Cut Pro Users Group
sunny jhooty
Re: P2 formatting
on Mar 29, 2011 at 8:59:22 pm
i have a unrelated question. does P2 Formatter not format the cards to FAT32? since i started using this program the clips from the camera dont split up at 4gb of use.
Jeremy Garchow
Re: P2 formatting
on Mar 31, 2011 at 3:47:09 pm
[sunny jhooty] "does P2 Formatter not format the cards to FAT32?"
Yes it does, otherwise your camera wouldn't be able to use them.
[sunny jhooty] "since i started using this program the clips from the camera dont split up at 4gb of use."
your MXF files are bigger than 4GBs? I have to say I don't believe you. The resulting quicktime movie form log and transfer might be bigger than 4GBs, but the mxf file won't be.
