IMPORT problem, tape quality question/problem?
COW Forums : Panasonic Cameras
Patricia Bernstein
on Mar 15, 2011 at 10:38:46 pm
I have taped 7hours of footage on mini HDV tapes... I am having import problems for FCP... I can't figure out what format the footage is in. I think it's just 480i, which means then that it's almost useless for film fests and such....
is it possible maybe i recorded in 720 or 1080i on the HDV tape?
or am i just nuts...
Steve Eisen
Re: IMPORT problem, tape quality question/problem?
on Mar 16, 2011 at 4:28:19 am
Your guess is as good as mine. What camera did you use to shoot with? Do you have access to that camera? What deck are you trying to log and capture from? A lot of unanswered question to give you a correct answer.
Steve Eisen
Eisen Video Productions
Vice President
Chicago Final Cut Pro Users Group
Patricia Bernstein
on Mar 16, 2011 at 4:43:35 am
I'm using the Panasonic Ag hdx200. I am using FCP 6 to log n capture from mini Hdv tape. I own the camera.
Not sure what else....
Shane Ross
on Mar 16, 2011 at 5:16:11 am
That camera doesn't shoot HDV. It either shoots DVCPRO HD to P2 cards, or DV to tape. It does not shoot HD to tape...and definately not HDV. If you shot to tape, you shot DV. Use the DV/NTSC Easy Setup to capture that tape.
Sorry...it isn't in HD.
Shane
Patricia Bernstein
on Mar 16, 2011 at 5:42:35 am
thanks
that is what I thought I was reading today... so i will try the easy set up tomorrow.
thank you again!
