P2 work flow
COW Forums : Panasonic Cameras
Lee Hopper
P2 work flow
on Feb 7, 2011 at 11:04:11 pm
I do live events, I will be using P2 cards to capture, and have capability to upload during the 12 hour event.
BIG question, what type of computer and software do I need?
I will bedoing very little editing of clips...adding a overlay tittle, then burn a bluray dvd, with multiple chapters or clips
your help is greatly appreciated
I am using an hpx500 and panasonic card reader
THANK YOU
Shane Ross
Re: P2 work flow
on Feb 8, 2011 at 2:46:10 am
[Lee Hopper] "BIG question, what type of computer and software do I need?"
Well...pretty much anything will do it, software wise. Avid Media Composer and Adobe Premiere work with the MXF files the camera produces natively...but you still need to copy the files from the cards to a media drive, AND back them up. FCP wraps the footage into QUicktime. FOr that workflow, you can watch this: Tapeless Workflow for FCP 7 Tutorial
So pretty much any major editing application will do.
Computer? Well, on the Mac side, MacPro, MacBook Pro...iMac, MacMini...will all work. Firewire 800 drive will playback the footage fine
BLURAY encoding? You need Toast 10 or Adobe Encore.
Shane
Miodrag Ristic
Re: P2 work flow
on Feb 10, 2011 at 9:25:53 am
Sounds easy :)
Jurgen Hoppe
Re: P2 work flow
on Feb 11, 2011 at 12:43:17 pm
In case you work with FCP, Raylight software might be helpful. It creates instantly .mov reference files and can be imported to FCP without time consuming Log/Transfer.
