Set up time lapse on Panasonic AG-HVX200
COW Forums : Panasonic Cameras
Thomas Mazzarella
on Jan 28, 2011 at 3:07:14 pm
I have a Panasonic AG-HVX200 and looking to record a time lapse sequence.
Can anyone tell me what settings I should turn on in the camera?
Thomas Mazzarella
Chris Tompkins
Re: Set up time lapse on Panasonic AG-HVX200
on Jan 28, 2011 at 4:14:36 pm
Interval Recording P.49:
Chris Tompkins
Video Atlanta LLC
Thomas Mazzarella
on Jan 28, 2011 at 7:40:05 pm
Chris, when I get to the interval time screen, it says 2f to the right, should I be able to go into that and change that 2f to something else? It's no allowing me to do that. Have any ideas?
Thomas Mazzarella
Chris Tompkins
on Jan 28, 2011 at 7:58:03 pm
Well the 2f is the default, if you cannot change that then you need to make sure you are set up correctly to interval record.
Did you select interval record?
Are you in 720 record mode?
Chris Tompkins
Video Atlanta LLC
Thomas Mazzarella
on Jan 28, 2011 at 8:10:26 pm
I am in 720p, and do I go under recording set up first? then listed is interval time. is this correct?
Thomas Mazzarella
Chris Tompkins
on Jan 28, 2011 at 9:09:13 pm
I believe so yes, I don't have the cam in front of me.
Choose interval recording.
Chris Tompkins
Video Atlanta LLC
Thomas Mazzarella
on Jan 28, 2011 at 11:00:29 pm
I still cannot get to that setting. Is there a step by step process somewhere, the manual is no real help.
Thomas Mazzarella
Dave Neyman
on Jan 29, 2011 at 1:50:12 am
Do the following:
1. Scene File - Set Operation Type to Video Camera
5. Recording Setup - Set Recording Format to 720P/60P
5. Recording Setup - Set Rec Function to Interval
5. Recording Setup - Set Interval Time
You need to do the math to figure out the best interval time. It depends on how fast you want it to play back.
Thomas Mazzarella
on Jan 29, 2011 at 2:29:13 am
Interval is set at 2f in blue color and cannot change it. where do I go from there?
Thomas Mazzarella
Dave Neyman
on Jan 29, 2011 at 2:59:12 am
You got me. I'm not sure why yours is not working. Mine works fine. My menus is as follows:
Rec Format
480i Record Mode
Rec Function
One Shot Time
Interval Time
Etc.
The menu selection you want is INTERVAL TIME. Is it possible that you are looking at ONE SHOT TIME?
Andrew Milner
on Aug 28, 2011 at 11:54:25 am
The above information was very helpful. Would you set your camera to auto iris and shutter?
Chris Tompkins
on Aug 28, 2011 at 1:39:46 pm
For time-lapse you want to be in Manual Iris.
You cannot adjust the iris once recording has begun.
Well, you can, all you want, but the results will not be favorable.
Shutter doesn't matter so much. Follow the 180 rule and you'll be fine.
Chris Tompkins
Video Atlanta LLC
Andrew Milner
on Aug 28, 2011 at 1:50:12 pm
Thank you. Now, I have to wait for the haze and dust to clear.
Thomas Imbrigiotta
on Feb 14, 2012 at 4:35:36 pm
Hmmmm, I pulled out our P2 and have the same problem. Most options are colored in blue and non-editable. I'll poke around and let you know what I find.
T.J. Imbrigiotta
Envision Communications, Inc.
Washington DC
http://envisioncommunicationsinc.com
Mac Pro
2 x 2.26GHz Quad-Core Intel Xeon
12GB RAM
Blackmagic DeckLink HD Extreme 3D - Video
ATI Radeon HD 4870 - GPX
Mac OS 10.6.8
Adobe CS5.5
FCP7
FCPX
Thomas Imbrigiotta
on Feb 14, 2012 at 4:45:37 pm
The solution for the locked blue menu options was already mentioned above. Make sure the Scene File is set to Video Camera not Film Camera.
T.J. Imbrigiotta
Washington DC
Mac Pro
12GB RAM
Mac OS 10.6.8
Adobe CS5.5
FCP7
FCPX
May Lerum
on Aug 26, 2012 at 6:13:58 pm
Thanks from Norway :)
Joseph Warren
on Mar 11, 2013 at 2:07:38 pm
Thanks From LV, this is exactly what I was looking for and it worked like a charm. Like the bleow post says, make sure you do step 1 and set the operation to video camera, not film camera.
Thanks again!
Pat
