P2 Copy to Hard Drive via Firewire
COW Forums : Panasonic Cameras
Mike Turecamo
on Jan 14, 2011 at 1:53:57 pm
Good morning, I'm trying to copy P2 cards directly to a G-Tech hard drive. I follow the steps correctly. When I get to the in camera menu that should allow me to copy the only option I get is set up, the other options are shaded and can't be accessed. Anybody have a clue?
Mike
Shane Ross
Re: P2 Copy to Hard Drive via Firewire
on Jan 14, 2011 at 4:35:26 pm
If I recall right, The only way to copy directly from a camera to a hard drive is via USB. It doesn't work via Firewire.
Shane
Mike Turecamo
on Jan 15, 2011 at 5:11:53 pm
Hi Shane Mike here...there are instructions to transfer directly to hard drive...its also on the menu
Mike
Mike Ironriver
on Feb 18, 2011 at 5:06:20 am
Just to make sure: you need to choose the firewire Host option in the menu. (Last menu point - Other Functions.)
Mike Ironriver
on Feb 18, 2011 at 5:11:48 am
It works fine on mine with firewire. Just to make sure: you need to choose the firewire Host option in the menu. (Last menu point - Other Functions.)
If you are using an G-tech mini drive (2.5 form factor) you need to provide power separately. Firewire doesn't provide power for the drive.
