1080 24p scenes reverse telecine'd won't render?
COW Forums : Panasonic Cameras
Tom Matthies
on Dec 21, 2010 at 2:11:46 am
I shot footage with my HVX200 as 1080 at 24P. Since the files are actually 1080p over 29.97 and have pull down interlacing, I ran the them through Cinema Tools and reverse telecine'd them, removing the pulldown and converting them to 23.98 for editing. All works well during the edit process with no pull down issues. This was all green screen compositing so interlacing would not be a good thing.
When it came time to render, it wouldn't. Instead I got this error message: "Codec not found. You may be using a compression type without the corresponding hardware card."
The original footage is DVCProHD. I'm editing in a 1920x1080 ProRes 422 seqence. The converted files, when played in Quicktime indicate that they are still in the DVCPro HD format. The original files with pulldown work fine and render. The files with pulldown removed won't render at all. Any ideas?
Tom
E=MC2+/-2db
Dave LaRonde
Re: 1080 24p scenes reverse telecine'd won't render?
on Dec 21, 2010 at 9:09:59 pm
Have you tried the usual litany of Things To Do when FCP misbehaves? Shut Down/Power Up, Trash Preferences, Repair Permissions, run Disk Warrior?
Dave LaRonde
Sr. Promotion Producer
Tom Matthies
on Dec 21, 2010 at 11:36:06 pm
Yep. For some reason it just doesn't like the footage that was run through Cinema Tools. It plays fine while editing. Composites to Green Screen very cleanly without interlacing. It just doesn't want to do a final render. If I play the footage in Quicktime and look at info, it indicates that the files are DVCPro HD, as it should. All looks good just playing them back either in QT or FCP. This is the only time I've seen this. Something with the pseudo 1080/24p from the HVX.
Weird...
E=MC2+/-2db
