Maximizing P2 transfer speed (XP, Cardbus)?
COW Forums : Panasonic Cameras
Kevin McRoberts
on Dec 20, 2010 at 4:13:00 pm
I have a used Dell D410 XP 12" laptop I'm going to be using as a P2 card backup device. The plan is to upgrade to a 320GB internal HDD, plus an external USB drive for backup verbose redundancy.
Initial tests are a little disappointing so far... using P2CMS, a full 32GB card took over 45 minutes to transfer to only the internal.
What are my options to improve this, costs, speed gains, etc?
Shane Ross
Re: Maximizing P2 transfer speed (XP, Cardbus)?
on Dec 20, 2010 at 6:49:47 pm
Hmmmm...a 32 GB card takes me about as long to offload using my Powerbook. 40 min. If you want faster speeds you need to look into the Panasonic 5-card reader with PCIe...and a tower computer. That's the fastest way to offload. Not very portable though. You kinda give up speed when you choose portable.
Shane
Helmut Kobler
on Dec 24, 2010 at 7:09:50 am
You should look into the Panasonic PCD2 USB card reader. I wrote a review here at the Cow (http://library.creativecow.net/kobler_helmut/panasonic_pcd2/1)
I didn't test the reader on the PC, but on the Mac, under various scenarios, I copied a 32GB E series card much faster than 45 minutes.
documentary camera
http://www.varicaminla.com
