Hvx200 Frame rate problem.
COW Forums : Panasonic Cameras
Stuart McIntyre
on Dec 20, 2010 at 3:00:00 pm
Bought another second hand HVX200 for Documentary use. The most recent camera that i got goes to 50fps each time i turn it off and i have to go through the menu to reset it. I'm sure you understand that this is not ideal when its use is for documentary. This is probably just a stupid mistake that i am making. But i would really appreciate if someone could point out what the problem is
Many thanks!
Stuart.
Frank Nolan
Re: Hvx200 Frame rate problem.
on Dec 23, 2010 at 12:19:32 am
Are you saving the setting, before you turn it off, when you reset it?
