MXF through Raylight Issues
COW Forums : Panasonic Cameras
Tommy Talley
on Nov 8, 2010 at 10:31:34 pm
Camera : HPX-500
Settings : 720 30p
Edit : FCP
Contents from P2 Card dropped in project folder.
Using Raylight to convert MXF to QT
Files are just appearing black in Finder Preview.
Files are just appearing black when opened in QT
Error reading "General Error" appears when dropping the footage in FCP.
Meta data appears to be there, because clip length and name are all visible.
Footage plays fine in camera from P2 card.
Footage plays fine through P2CMS
Thoughts?
Thanks in advance.
tommy talley
contrastfilms.net
tommy@contrastflms.net
"Take dead aim on the rich boys. Get them in the crosshairs and take them down. Just remember, they can buy anything but they can't buy backbone. Don't let them forget it. Thank you." - Herman Blume
David Keslick
Re: MXF through Raylight Issues
on Nov 9, 2010 at 12:48:20 am
Here are some possible reasons that you are getting black video.
Delete the link and rescan the MXF files. Make sure each folder in the path to your MXF files has a folder name less than 32 characters. Make sure the drive is formatted Mac OS Extended if you use long file names such as file names with the MetaData "User Clip Name". Make sure you have the DVCPROHD components installed by FCP 5 or 6. They are in the Library/Quicktime folder on your system drive, six files that start with "DVCPROHD" and end with ".component". If the slate frame is visible but no other frames are, most likely the original MXF files have moved or the path to the MXF files have a bad character or uses a folder name greater than 32 characters. If your source files are stored on an external volume, try renaming the volume to a shorter name with no spaces or special characters.
If you are still having problems please go to http://dvfilm.com/support.htm
Dave Keslick
DVFilm.com
