P2CMS software issue
COW Forums : Panasonic Cameras
Chris Anderson
on Nov 4, 2010 at 9:01:47 pm
I am using the P2CMS software on a windows machine and I get the following message when I try to view a copy of a P2 card.
"hit number as a result of search exceeds number of display. Please reduce it's number by search refinement or reset display number in option.(maximum:1"
Anyone experience this before or know what this is about?
it opens other cards fine.
Chris
Chris Anderson
Chris Anderson
Re: P2CMS software issue
on Nov 4, 2010 at 9:41:49 pm
I figured it out. Though it is not that obvious.
I needed to go to the "Tool" menu. Click the "Setting Metadata" Tab and change the "Number of Displaying" which I guess defaults to 100 clips.
I wish that was more clear because with these larger cards it's easy to pass 100 clips.
Chris Anderson
