Vid Rate + FS100
COW Forums : Panasonic Cameras
Chris Tompkins
Vid Rate + FS100
on Sep 24, 2010 at 5:31:18 pm
Shot 720-30p on P2 Cards with a 170
Same time shot 720-30p onto a FS100 to QT's with a 200
Now, when I bring them both into FCP to edit.
They both show Compressor@ DVCPROHD 720p60 - good.
BUT, the P2 files read a vid rate of 29.97
and the QT's off the FS read a vid rate of 59.97
WHY?
Chris Tompkins
Video Atlanta
Jeremy Garchow
Re: Vid Rate + FS100
on Sep 24, 2010 at 6:10:18 pm
Sounds like you FS100 was set to record in P mode, not pN.
When importing the P2 footage, I imagine that your preferences were set to remove duplicate frames. This results in 30pN files. If you uncheck that option and reimport, your clips should be 59.94 (30p with 2:2 pulldown) like the fs100's clips.
Jeremy
Chris Tompkins
on Sep 24, 2010 at 6:29:26 pm
SWEET!
Thanks so much, it worked!
Chris Tompkins
Video Atlanta
