Frame rate screw up
COW Forums : Panasonic Cameras
Kevin Worthy
Frame rate screw up
on Sep 20, 2010 at 2:12:53 pm
I have 2 camera angles of a football game. one was shot at 30pn and 30fps. the other one was shot at 30pn and 24fps. I was wondering how to make this footage match and one not appear to be sped up. HELP!
Michael Sacci
Re: Frame rate screw up
on Sep 20, 2010 at 5:53:39 pm
Yeah, you don't.
The only way to fix this is to add a pulldown to the 24fps footage. This will not be the cleanest since it has to make up six frames by combining two frames together to make a third frame.
You need to teach the camera persons running these cameras that if you are not seeing audio meters bouncing there is a good chance that you have a frame rate mismatch.
