Problems with 32gig P2 card and copying files to Macbook Pro
COW Forums : Panasonic Cameras
zack hill
on Sep 17, 2010 at 8:49:24 pm
Hello,
Been googling this and have found no answer, hoping someone has a thought on what I can do:
Problem:
Shot 4 all day timelapses at 720 30p, interval record - clips showed up fine and played but I did not copy to a disk.
Today without offloading the timelapse clips, I shot some water footage at 720 24pn at 60fps.
When I opened up the clips in VTR mode on my HVX, the 4 timelapse clips show up with red around the thumbnail. I cannot delete them.
My other clips show up normal and play fine in the camera.
When I try and drag my contents folder and TXT file, it won't copy - it just waits and says getting ready to copy 364 items. Iet it sit for 3 hours hoping it was copying, but it wasn't.
When I mount the card in Log and Transfer in FCP, the water clips play, and I was able to capture one but then I get the dreaded spinning ball and I am forced to force quit FCP.
Help!!!
I don't want to reformat this card and lose my clips! (who would?)
thanks
Zack Hill
http://www.zeechproductions.com
HVX200a
Zack Hill
Jeremy Garchow
Re: Problems with 32gig P2 card and copying files to Macbook Pro
on Sep 17, 2010 at 9:21:47 pm
[zack hill] "When I opened up the clips in VTR mode on my HVX, the 4 timelapse clips show up with red around the thumbnail. I cannot delete them."
You camera has to be in the mode that you shot, so if you shot 30p, camera has to be in 30p, if you shot 24pN, camera has to be in 24pN.
As far transfers go. how are you trying to transfer? A card reader?
zack hill
on Sep 17, 2010 at 9:25:55 pm
Ahhhh.... that makes sense!
I am trying to transfer via firewire
any other ideas on how to get the footage off of my camera?
thanks Jeremy
zack
Zack Hill
Jeremy Garchow
on Sep 17, 2010 at 9:26:24 pm
[zack hill] "any other ideas on how to get the footage off of my camera?"
USB in USB device mode.
zack hill
on Sep 17, 2010 at 9:28:41 pm
ok, i'll give it a shot, thanks for your help Jeremy
zack
Zack Hill
zack hill
on Sep 17, 2010 at 11:58:48 pm
That worked Jeremy!
USB device worked, (or is working...)
downloading clips now!
thanks
zack
Zack Hill
Jeremy Garchow
on Sep 18, 2010 at 12:05:30 am
Huzzah.
Steve Eisen
on Sep 19, 2010 at 3:17:47 am
Back up your card before reformatting. Make duplicate copies on separate hard drives. These are your master files.
Steve Eisen
Eisen Video Productions
Vice President
Chicago Final Cut Pro Users Group
John Fishback
on Sep 20, 2010 at 3:46:44 pm
And always safe your cards before copying or transferring.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24" TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)
zack hill
on Sep 21, 2010 at 4:30:56 am
Hey, since I got your guys attention, is USB way faster?
Normally with Firewire (connected to my external via my camera) it takes almost an hour to download one 32 gig card.
With USB I downloaded 28 gigs in about 20 minutes. I had the USB going from my camera to my computer and depositing data onto my g-raid. Seemed way faster than firewire.
thanks
!zack
Zack Hill
Jeremy Garchow
on Sep 21, 2010 at 2:56:03 pm
[zack hill] "With USB I downloaded 28 gigs in about 20 minutes. I had the USB going from my camera to my computer and depositing data onto my g-raid. Seemed way faster than firewire."
Theoretically, it's not supposed to be, but P2 seems to work very well via USB and Macs.
Another thing is that by going USB from camera, you aren'y tying up the firewire bus with both a camera and your GRaid. This is probably what is causing the faster throughput.
I highly suggest getting the $350 Panasonic USB single card reader.
Jeremy
Bill Nelson
on Mar 4, 2011 at 7:47:05 pm
Zack et.al.
How does one mount a P2 card to the Mac via USB?
thanks!
zack hill
on Mar 4, 2011 at 8:53:58 pm
Hi, I don't have my camera in front of me, but you can go into the camera menu and where the setting is for 1394 (firewire) to mount the disk, you can change that setting to USB.
If you can't find it let me know and when I get home from work I will look at my camera!
thanks
zack
Zack Hill
Bill Nelson
on Mar 5, 2011 at 1:26:27 am
very cool, thank you
