P2 Reader PCIe adapter for MacBook Pro
COW Forums : Panasonic Cameras
Robert Gilkes
on Aug 31, 2010 at 2:42:33 pm
I have a Panasonic AJ-PCD35P P2 Card Reader, but unfortunately it uses a PCIe interface and I want to also connect it to my MBP. Is there any adapter I can buy to hook it up to my MBP?
Please note I have the latest model 15in MBP that does not have an Express 34 Slot.
Thanks for all your help!!
Shane Ross
Re: P2 Reader PCIe adapter for MacBook Pro
on Aug 31, 2010 at 6:11:53 pm
Man...you have a MBP without Express34? Seriously crippled machine. You can't use this then...
http://sewelldirect.com/ExpressCard-to-PCI-Express-Adapter-Full-Length.asp
From my research, there isn't an option to go from PCIe to Firewire or USB. Just isn't done. And any adapter might run you more than $350...so why not just get the USB P2 single card reader that Panasonic makes?
Shane
Robert Gilkes
on Aug 31, 2010 at 6:15:32 pm
I'm not a huge fan of the size of the 17in MBP. The single card reader is nice, but it's just that...a single card reader. I may just put this one on eBay. I'm pretty sure Panasonic released the same reader I have with a USB2.0/FW800 interface sometime after.
Shane Ross
on Aug 31, 2010 at 6:19:21 pm
I wouldn't get rid of this. USB is SERIOUSLY SLOW compared to PCIe direct. You will never get the same speeds you get from that device.
Look for a used Powerbook on eBAY...one with a built in slot. I keep one just for this purpose.
Shane
Michael Sacci
on Aug 31, 2010 at 6:38:22 pm
https://panasonic.ca/english/broadcast/p2/AJPCD20.asp
but it is slower transfer.
Any the lack of Express34 is a bad thing for the video world with the 15"
Who cares about a slot that replaces an $20 adapter.
Robert Gilkes
on Aug 31, 2010 at 6:58:35 pm
Yea, that's exactly what I was referring to.
I wish the Express slot would have stayed. I have so many SD card readers that came with cameras, cards, etc. I don't know what to do with them anymore.
Dan Brockett
on Aug 31, 2010 at 8:45:43 pm
I just was given a new 15" too. The loss of the FW 400 slot, Expresscard 34 slot and the glossy screen relegate this laptop to an e-mail, web browsing machine, it is not equipped to do serious video production anymore. Wish I would have had the choice for a 17" model, although I too don't like lugging the bigger 17" around. It wouldn't fit into my CineBags CB-25.
FWIW, I bought the AJ-PCD2 and it is surprisingly fast, I have been pretty happy with it so far. It is not as fast as PCI-E, but it is faster than I thought it would be.
Dan
A Producer Who Is Also A DP? Yep, that's Me.
http://www.danbrockett.com
Arthur Aldrich
on Sep 2, 2010 at 5:11:37 pm
I needed to do the exact same thing.
I experimented with a Matrox MXO2 PCI adapter and it works great.
Read more about my experience here:
http://p2pro.com/worlds-fastest-p2-offloader
Art Aldrich
OTEK TV
Leader, NJFCPUG
http://www.njfcpug.org
http://www.otek.tv
Robert Gilkes
on Sep 2, 2010 at 5:34:01 pm
Thanks Art, but the problem (as stated in the original post) is my 15in MBP doesn't have the Express35 Slot.
Helmut Kobler
on Sep 3, 2010 at 7:11:09 am
Unfortunately, you're out of luck Robert, given that particular Mac. If you need 5 slots, then the PCD20 is the only option....but it's so damn expensive for a USB2/FireWire 800 card reader (and the FW800 speed is just as slow as USB2 on the PCD20).
If you can make due with copying one card at a time, then then PCD2 is a better value.
