Using good mark in FCP
COW Forums : Panasonic Cameras
Burt Holland
on Aug 6, 2010 at 6:00:40 pm
I just shot a ton of footage on my HPX-500 and used the mark good feature for the first time. I can see the marks once I transfer the footage, but not in the Log and Transfer window, which is where I need it. What am I missing?
Jeremy Garchow
Re: Using good mark in FCP
on Aug 6, 2010 at 6:52:42 pm
[Burt Holland] "What am I missing?"
Metadata.
Using P2 Flow, that information will come across as it is written in to an XML and sent to FCP. You can then log and transfer from there.
Jeremy
Burt Holland
on Aug 9, 2010 at 4:17:51 pm
Looks like a good product but I'd rather not spend 499 EU. Does log and transfer not see this portion of the metadata?
Jeremy Garchow
on Aug 9, 2010 at 4:52:17 pm
[Burt Holland] "Does log and transfer not see this portion of the metadata?"
Log and transfer does not, as the column does not exist in that interface, but AFTER log and transfer, the good column is checked.
Jeremy
