HVX200 into Macbook pro (2007) for Ustream
COW Forums : Panasonic Cameras
michael alexander
on Aug 6, 2010 at 4:01:05 pm
I am trying to stream from my panasonic hvx200 to my macbook pro (2007) using ustream producer but can't get a picture, I tried the 1394 firewire to no avial.
then i downgraded the output to SV 480i using the firewire cable but still no picture,
It looks like a need to take an analog or s video cable out of the camera, but how do I bring it into the macbook, is there a special converter that mac sells or something else?
thanks!
Michael
Conscious Living TV
Media for Social Change
Shane Ross
Re: HVX200 into Macbook pro (2007) for Ustream
on Aug 6, 2010 at 4:09:21 pm
Yeah, you can't stream via firewire...and you can only get SD out of the Component connection. And for that you will need a capture device...something that works with a MacBook Pro with Express 34 slot. Matrox MXO2 Mini. Or, since you can only get SD, a Canopus AVCHD 110...converts analog to DV.
Shane
