TC from video out on HPX500P
COW Forums : Panasonic Cameras
Jeff Ongstad
on Jul 29, 2010 at 5:13:49 pm
Is there a way to get time code out of the Panasonic AG-HPX500P to an external monitor by way of the video out? We are trying to do this for a client so they can take notes from the big screen monitor.
Jeff
John Fishback
Re: TC from video out on HPX500P
on Jul 29, 2010 at 6:47:19 pm
It'll output the video with t/c and other info supered. You set it up in the Display menu (I think). It's definitely in the menu structure. If you have a timecode reader you can feed it from the t/c out of the camera.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24" TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
Jeff Ongstad
on Jul 29, 2010 at 9:15:31 pm
I thought it would be in the Display Menu too, which is partially true. You also have the have the Character Output button on the side set to on. Who knew, a real button...Thanks for your help.
Jeff
