trying to offload P2 files on my Mac through USB out of camera
COW Forums : Panasonic Cameras
ben traylor
on Jul 14, 2010 at 8:25:32 pm
Hey guys,
I'm trying to input P2 files on my macbook pro through the USB output on my HPX500. i can see the files on my computer. do i need to download any software to make them play? i do not want to firewire into final cut. i'd rather offload on to my computer and then transfer to an external hard drive and give to a friend.
thanks in advance.
http://www.bentraylor.com
Noah Kadner
Re: trying to offload P2 files on my Mac through USB out of camera
on Jul 14, 2010 at 8:42:13 pm
Read your manual for Firewire device connect- USB will take you just slightly less time than forever. You want to copy over the entire contents of the card and back them up before FCP even gets into the mix.
Noah
Check out my book: RED: The Ultimate Guide to Using the Revolutionary Camera!
Unlock the secrets of 24p, HD and Final Cut Studio with Call Box Training. Featuring the Sony EX1 Guidebook, Panasonic HVX200, Canon EOS 5D Mark II and Canon 7D.
Learn DSLR Cinematography.
Shane Ross
on Jul 14, 2010 at 10:58:56 pm
[ben traylor] "do i need to download any software to make them play?"
To VIEW them, after you download? Yes. P2CMS is free, and allows you to view them. Other options are paid.
And yes, USB can take forever...the firewire connection is faster. And copy the ENTIRE card contents...everything. Best if you used software to do this, like Shotput Pro, by http://www.imagineproducts.com. It does this for you, and verifies the data as it copies. If you have this camera, this software is pretty much a requirement.
Shane
ben traylor
on Jul 15, 2010 at 1:39:01 am
thank you both for your help. very appreciative.
take care,
ben
