hooking a standard Def monitor to my HPX 170- no signal
COW Forums : Panasonic Cameras
Danielle Lussier
on Jul 9, 2010 at 6:42:32 pm
I have tried to hook my hpx 170 composite AV cord / and SDI cord with 1/8 " mini plugin to an external Standard Definition LCD Monitor and I do not get a signal. Can some one help me understand why? I know there must be a compatibility issue but I am unsure as to where the issue is?
Jim Carswell
Re: hooking a standard Def monitor to my HPX 170- no signal
on Jul 9, 2010 at 6:48:45 pm
You are sending an HD signal to a non HD monitor. The monitor is not capable of down converting the signal.
Jim
Jim Carswell
Spyhop Productions, Inc.
Savannah, GA
http://www.spyhopproductions.com
Sohrab Sandhu
on Jul 9, 2010 at 7:49:33 pm
Go to the menu options, select the 480i option in the AV playback option.
You should be able to get SD signal on your monitor now.
2.66 GHz 8-core, ATI Radeon HD 4870,
FCS 3, AJA Kona Lhi
"The creative person wants to be a know-it-all. He wants to know about all kinds of things: ancient history, nineteenth-century mathematics, current manufacturing techniques, flower arranging, and hog futures. Because he never knows when these ideas might come together to form a new idea. It may happen six minutes later or six months, or six years down the road. But he has faith that it will happen." -- Carl Ally
Steve Eisen
on Jul 10, 2010 at 3:19:39 am
Your only option is Composite (Yellow, Red and White) or Component (breakout cable with Green, Red and Blue) if your LCD has those inputs.
SDI will ONLY work with a monitor with an SDI input.
I'm not understanding your SDI with 1/8" plug. This definitely is NOT and SDI cable. SDI is BNC to BNC.
Steve Eisen
Eisen Video Productions
Vice President
Chicago Final Cut Pro Users Group
Danielle Lussier
on Jul 12, 2010 at 2:49:22 pm
Thanks for your input- I realize now what I was doing- and I finally found the AV connection above the xlr hookup. Silly me. Thank you for your responses - very helpful!
