p2 card unable to read
COW Forums : Panasonic Cameras
Gerald Sievers
on Jul 9, 2010 at 1:26:48 am
One of my p2 cards is filled with thumbnail images. I am unable to view them on the camera. Each thumbnail has a red x on the top right corner (each one has zero duration).
Is the card corrupt? Is there a setting problem?
Noah Kadner
Re: p2 card unable to read
on Jul 9, 2010 at 1:57:03 am
have you tried the Fix clip function in the camera- check your manual for details.
Noah
Check out my book: RED: The Ultimate Guide to Using the Revolutionary Camera!
Unlock the secrets of 24p, HD and Final Cut Studio with Call Box Training. Featuring the Sony EX1 Guidebook, Panasonic HVX200, Canon EOS 5D Mark II and Canon 7D.
Learn DSLR Cinematography.
Jeremy Garchow
on Jul 13, 2010 at 2:19:25 pm
Also, your camera must be in the same format as the footage shot in order to playback. If the footage is 720pN24 AVC-Intra, your camera can't be in 1080p30 DVCPro HD. If you switch your camera to match the footage, you should be all good.
