 | P2 clip into FCP
on Jun 11, 2010 at 12:11:12 pm |
Hi all,
I know that FCP CAN import P2 files from log and transfer option,
but i would like to know if there is somewhere an otion to rename the clips. (Very annoying the naming P2 does).
If not (which i think there is not) i would like to know if there is another utility that can do that thing for me.
Free is better...
Thanks in advance,
Yiannis
 | Re: P2 clip into FCP on Jun 11, 2010 at 2:48:28 pm |
P2CMS can rename claips, but it's not better than log and transfer, but it is free.
The one that I use which is not free is P2 Flow from MXF4mac. Worth every cent. Very fast and easy to edit metadata.
 | Re: P2 clip into FCP on Jun 11, 2010 at 6:36:45 pm |
If you just want to rename clips, you can do that in the L&T Clip Name field. And, if you name the folders holding each P2 card appropriately, like Cow Shoot-date-1, 2..., that will appear as Reel info in L&T.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24" TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
