What battery do I need for my HPX170 Remote Control?
COW Forums : Panasonic Cameras
Christopher Targia
on Jun 1, 2010 at 8:25:10 pm
I had battery for my HPX170 remote control, and after a year of use it died. So I just replaced it, used the same type of battery needed, CR2025, I bought two energizer CR2025 batteries, so I would have a backup. I put the first one in and nothing... I double checked the type of battery and everything and I couldn't figure out why it didn't work. So I tried the other battery. This one worked without a problem. I figured I had a defective battery. Only problem is, this battery only lasted for two days. Does anyone else with this camera know what kind of battery I should be using for this remote?
Before anyone makes a smart comment, I need the remote so I can run my teleprompter and the camera simultaneously without getting up.
Thanks for any help.
Michael Sacci
Re: What battery do I need for my HPX170 Remote Control?
on Jun 1, 2010 at 9:58:53 pm
The batteries you purchased could be bad. Have you tested them? What is their voltage?
If these batteries are good then maybe the remote is bad.
Christopher Targia
on Jun 2, 2010 at 12:55:41 pm
how do i test them, the only thing i have that uses this type of battery is the remote. They are 3v batteries.
MacPro Octo Core Intel Xenon 2.8Ghz 6GB 800MHz DDR2 Ram
FCP 7.0
Michael Sacci
on Jun 2, 2010 at 6:34:06 pm
a volt meter
