Scaling up in SD
COW Forums : Panasonic Cameras
peter tours
Scaling up in SD
on May 18, 2010 at 11:33:37 am
We have ftg shot on HPX500 @ 960x720 but will be releasing SD. The question: can I scale the video up past 100% in an SD timeline without deteriorating the image and if so how far?
Client wants on-camera talent shots tighter....
Peter Tours
TnT Video Services, Inc.
Fort Lauderdale, FL
John Fishback
Re: Scaling up in SD
on May 24, 2010 at 8:36:59 pm
Actually if you set up a SD anamorphic sequence and drop a DVCProHD clip into it, the clip will be scaled by FCP to somewhere around 75%. So you can zoom up to 100% with very little softening and probably well beyond, Try it one your system (I just did) and decide for yourself how far you can go. Let your client see it, too, and decide.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24" TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
