pixel problem
COW Forums : Panasonic Cameras
barthelemy glumineau
pixel problem
on May 9, 2010 at 3:26:35 pm
Hi, i work with an HVX 200 with some 32 and 16 gig P2 cards. Recently , from time to time, i get those anoying pixel problems. It always take place on only one frame and could happen a couple of time inside the same clip. I first thougth that it was a card problem, but since it occur on different card and randomly i start to think it s inside the camera (probably sensor) that the problem is generated.
RT Overlays (ignored by utest)
Any idea how to fix that. Should i send the camera back to Panasonic ?
Thanks in advance for all your inputs.
BART
http://www.strangefamilia.com
Noah Kadner
Re: pixel problem
on May 9, 2010 at 8:06:15 pm
That looks more like a major issue with your cards or some internal fault of the camera than an image sensor problem. At any rate- absolutely that is going to require servicing by Panasonic asap.
Noah
Check out my book: RED: The Ultimate Guide to Using the Revolutionary Camera!
Unlock the secrets of 24p, HD and Final Cut Studio with Call Box Training. Featuring the Sony EX1 Guidebook, Panasonic HVX200, Canon EOS 5D Mark II and Canon 7D.
Watch Formosa- My indie movie shot with the SDX900 and finished with Final Cut Studio.
John Fishback
Re: pixel problem
on May 9, 2010 at 10:11:22 pm
I recall a post that attributed this to dirty contacts in the camera and/or card. Unfortunately, the artifacts are in the clip. If they're not too big, perhaps a bad-pixel fixing plugin like Reincarnation from Digital Heaven would help remove them.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24" TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
Shane Ross
Re: pixel problem
on May 10, 2010 at 7:10:35 pm
In my experience, that was dirty contacts...dust. Try canned air first to clean the card and the slots, do some test shots and see if it is cleared up.
But yeah, the footage now permanently has those pixels, so that can't be helped. Just like tape heads can get dirty, so can tapeless contacts.
Shane
Dan Wolfe
Re: pixel problem
on May 10, 2010 at 8:31:12 pm
dunno if it's a dirty anything. I had this problem when copying from P2 cards with the protect switch disabled. when I enabled the protect switch and used shotput pro to do byte for byte verification the same footage imported glitch free. do you have access to the original footage on the P2 card?
