Convert HPX170 footage for Apple's Color?
COW Forums : Panasonic Cameras
Matthew Sonnenfeld
on May 4, 2010 at 5:00:37 pm
Hey all,
So my question is this... If I am planning to do some reasonably heavy color correction in Color, is it a good idea to convert the DVCPRO HD files to ProRes422 so that I am color correcting in a 10 bit environment over 8 bit DVCPRO HD, or will it hurt me due to adding an extra level of compression, or will it just not make a difference?
Thanks for your help!
- Matt
Panasonic HPX170 P
2008 Unibody Macbook Pro 15 inch, 2.8 Ghz, 4GB RAM
CalDigit VR
Final Cut Pro Studio 3
Avid Media Composer
The College of WIlliam and Mary
Noah Kadner
Re: Convert HPX170 footage for Apple's Color?
on May 4, 2010 at 5:23:17 pm
I'd go to ProRes HQ so you have more latitude and less noise to work with...
Noah
Check out my book: RED: The Ultimate Guide to Using the Revolutionary Camera!
Unlock the secrets of 24p, HD and Final Cut Studio with Call Box Training. Featuring the Sony EX1 Guidebook, Panasonic HVX200, Canon EOS 5D Mark II and Canon 7D.
Watch Formosa- My indie movie shot with the SDX900 and finished with Final Cut Studio.
Shane Ross
on May 4, 2010 at 6:19:10 pm
[Noah Kadner] "I'd go to ProRes HQ so you have more latitude and less noise to work with..."
ProRes HQ is for 10-bit codecs, and for workflows above 1080 (2K, 4K). ProRes 422 is for 8-bit formats, like DVCPRO HD. But I wouldn't convert before I color corrected. I'd stick with sending DVCPRO HD to Color, then rendering out as ProRes. Then you get the benefit of the 10-bit color space, but don't need to waste time converting.
Shane
