hpx300
COW Forums : Panasonic Cameras
Binder Garcha
hpx300
on May 4, 2010 at 6:26:43 am
hello i have hpx300 camera i shot on 720p x 1080p 24p i can't bring the file in to final cut pro. anyone help in this case
thanks
John Fishback
Re: hpx300
on May 4, 2010 at 4:22:11 pm
First off, is it 720P or 1080i. Simply, you ust the Log & Transfer process in FCP. How did you try to transfer the media and what problem did you have? Explain your workflow so folks can help you.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24" TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
Binder Garcha
Re: hpx300
on May 4, 2010 at 4:45:54 pm
I trasfer from hpx300 camera to macpro desktop firt i made folder on my macpro desktop then i use usb cable from camera to computer copy text file & folder. then i open fcp import file in to the bin it dos't work at all. when i go to the clip or video folder both file dos't work. it work on my pc with edius 5.5 same file
thanks
Binder Garcha
Re: hpx300
on May 4, 2010 at 5:02:11 pm
thanks
Binder Garcha
Re: hpx300
on May 4, 2010 at 5:02:37 pm
thanks
Jim Carswell
Re: hpx300
on May 4, 2010 at 9:05:44 pm
Do not use file>import. Use Log & Transfer to get the files into Final Cut.
Jim
Jim Carswell
Spyhop Productions, Inc.
Savannah, GA
http://www.spyhopproductions.com
Michael Sacci
Re: hpx300
on May 7, 2010 at 3:52:36 pm
May want to spend a few movements reading up on the workflow of the camera and FCP.
Ramandeep Dhillon
Re: hpx300
on May 10, 2010 at 1:25:33 am
Hi, which format did you shot? on AVC I 100 or DVCPRO HD, sometimes the problem is that there is no AVC I codec installed and it will not see the footage, I just got my hands on HPX 300 and I had to waste a week before i got the Full HD footage in my computer (pc though),
Punjabi Sports | Sports In Punjabi
HPX 300,Redrock Micro Matte box, Quad CPU Q9450 @2.66 GHz, 3.25 GB RAM
