Hooking up AJ-PCD35P to MacBook Pro
COW Forums : Panasonic Cameras
Matt Steeves
on Apr 23, 2010 at 6:33:38 pm
I just got an AJ-PCD35P for ingesting P2 cards into my MacPro edit bay using the PCI express card included.
I am not too familiar with PCI card types and slots, but what would I need to be able to hook up this piece of equipment to a MacBook Pro?
Jeremy Garchow
Re: Hooking up AJ-PCD35P to MacBook Pro
on Apr 24, 2010 at 2:10:10 am
Technically, you can't as Panasonic only made them for desktops.
But you can try this:
http://www.magma.com/pciexpress.html
No idea if it works or not.
Takashi Fujii
on Apr 24, 2010 at 5:41:55 am
I understand that Magma EX34 is the unit that will interface between the MBP with Express 34 slot and the Panasonic AJ-PCD35.
I don't own one but here are the links to the article and post:
http://www.studiodaily.com/main/technique/craft/f/editing/ROI-Review-Panaso...
http://www.dvxuser.com/V6/showthread.php?t=191562&highlight=Magma+EX34
Magma EX 34 ExpressCard/34 Host card, $199
http://www.magma.com/comersus_viewItem.asp?idProduct=19
Here's a closeup photo - the cable that comes with the PCD35 will fit EX34:
http://www.bhphotovideo.com/c/product/555002-REG/Magma_EX34_ExpressCard_34_...
T. Fujii
Doug Farris
on Jan 7, 2012 at 7:18:30 am
Hi Matt,
Just curious if you ever had any luck connecting the PCD35 to your laptop.
Doug
