All clips as 1 take?
COW Forums : Panasonic Cameras
Harry Pallenberg
on Apr 14, 2010 at 5:23:30 pm
Subject says it all... can you set the new 370 camer to have all the recorded clips show up as 1 take on the P2 cards?
You can do this on the JVC-700 that shoots to SDHC cards using the sony 35 codec.
Harry
Harry
Forum Cowmunity Leader: Indie & Doc
Forum Cowmunity Leader: HDV
Dual 1.8 G5 ** 2GB ** 10.5.4 (Office / Photoshop)
Dual 2.0 G5 ** 4GB ** 10.5.4 Kona 2 (FCP 6.0.4 Machine)
http://www.womeninboxes.com
The Documentary Film about Magic's Better Half.
Jeremy Garchow
Re: All clips as 1 take?
on Apr 14, 2010 at 10:10:19 pm
If the clip goes over 4GBs, no.
Emre Tufekci S.O.A.
on Apr 15, 2010 at 1:13:24 pm
I do believe it can:
"New advances in the HPX370 include one-clip REC function that records up to 99 consecutive cuts as a single clip, greatly facilitating nonlinear editing".
Emre Tufekci
http://www.productionpit.com
Harry Pallenberg
on Apr 15, 2010 at 2:51:00 pm
Sweet! Where did you find that quote?
Harry
Jeremy Garchow
on Apr 15, 2010 at 4:32:46 pm
It will do it, but any one clip cannot exceed 4GBs on a P2 card.
It's called one clip recording mode on our HPX2000. I seem to recall there are issues with it, though.
Harry, what are you trying to do and why do you need this function? Just curious.
Jeremy
Harry Pallenberg
on Apr 15, 2010 at 4:44:33 pm
The long story of what we are trying to do is here: http://forums.creativecow.net/readpost/99/859239
The short is that my boss makes a paper edit with timecode, then in the edit bay he tells the editor to go to 01:05:27 for example - and instead of having the editor have to open clip 1 and scrub only to find it stops at minute 3, then open the next clip and see it stops just before the moment we need, then finally open the right clip.
I know we can just dump them all on the timeline and export a new master clip - but wanted to save time & steps... and I figured that should be one of the benefits of modern computer / cameras.
Do you know where Emre got the quote about the Panny 370? Seems like that camera has a lot to like!
Harry
Jeremy Garchow
on Apr 15, 2010 at 4:58:14 pm
[Harry Pallenberg] "I know we can just dump them all on the timeline and export a new master clip - but wanted to save time & steps... and I figured that should be one of the benefits of modern computer / cameras. "
And if you did this, the timecode will now not match back to the original clips as it will match your sequence.
Timecode is easily viewable within FCP, you find the tc, load the clip, enter in the tc in the viewer and bingo. We do this all the time.
Honestly, I can't find the problem I remember reading about the one clip record feature not working in Log and Transfer. Perhaps it's been fixed.
If you google the 'HPX370 one-clip REC' I'm sure you will get 1,000 press releases saying as such.
Jeremy
Emre Tufekci S.O.A.
on Apr 15, 2010 at 7:59:19 pm
It seems I cannot post it where I got the quote from due to forum rules and restrictions. You will have to google it.
Emre Tufekci
Jeremy Garchow
on Jun 8, 2010 at 4:05:31 pm
As I was doing some firmware updating to my camera today (not the 370) one clip Rec is now supported in FCP 7.0.2. Just following up.
https://eww.pavc.panasonic.co.jp/pro-av/support/cs/csregistp2m/ep2main/soft...
Jeremy
