P2 problems when transferring
COW Forums : Panasonic Cameras
Wesley Whiteside
on Apr 7, 2010 at 4:33:52 am
I have a problem transferring P2 card footage to Final Cut. The first two cards worked fine, but for some reason the second two won't render properly.
I log and transfer the contents folder and when I play it back, the audio is all sped up while the clip plays in a jagged frame rate. The rendered clip ends before the whole take is finished.
I don't know why this is happening. Do you have any ideas on how to fix it?
Ari Grunzeweig
Re: P2 problems when transferring
on Apr 7, 2010 at 1:22:41 pm
My suggestion would... in log and transfer, go to your prefs (a small drop down in the middle on top, and then unselect remove duplicate frames...)
Good luck!
