Weird Vertical Lines Appear on HVX200a
COW Forums : Panasonic Cameras
Brandon Dull
on Mar 19, 2010 at 10:41:34 pm
I am experiencing vertical lines while shooting on my HVX200a. They are off center to the right on the frame. Does anyone know why these are appearing?
I have also put more frame rates on a SD card and loaded them into the camera. Could that be a possibility of these vertical lines showing up? I have started to experience the lines after the frame rates were loaded into the camera.
Can anyone help to reset the scene file settings to factory settings or fix the problem as is?
Thank you much,
Brandon Dull
Brandon Dull's Links:
http://BrandonDull.com
http://Vimeo.com/BrandonDull
http://twitter.com/BrandonDull
Michael Sacci
Re: Weird Vertical Lines Appear on HVX200a
on Mar 19, 2010 at 10:57:13 pm
[Brandon Dull] "Can anyone help to reset the scene file settings to factory settings "
Can you not look this up in the manual? Noah may no this by heart but I would have to look it up.
Is the line on the footage or just the viewfinder?
