hvx200 variable frame rates
COW Forums : Panasonic Cameras
James Carroccio
on Mar 6, 2010 at 9:21:55 pm
Hey guys,
Trying to overcrank/Undercrank while using the hvx200.
set the frame rate to 720p/60
shot.
Ingested content to fcp.
Playback is normal (not slow mo)
I pretty sure there is another internal application that im not setting.
Any advice would greatly be appreciated.
thx
James
Camera Operator
Noah Kadner
Re: hvx200 variable frame rates
on Mar 6, 2010 at 11:24:51 pm
Did you read the manual? You want to shoot 720p/24pN and then pick a record frame rate- 0-60fps. Shooting 720p/60 is not variable framerate it's 720p/60. If you want it to look slow mo now, use the Speed control in FCP and slow it down by a percentage. Make sure to click blend frames off.
Noah
Check out my book: RED: The Ultimate Guide to Using the Revolutionary Camera!
Unlock the secrets of 24p, HD and Final Cut Studio with Call Box Training. Featuring the Sony EX1 Guidebook, Panasonic HVX200, Canon EOS 5D Mark II and Canon 7D.
Watch Formosa- My indie movie shot with the SDX900 and finished with Final Cut Studio.
Steve Eisen
on Mar 6, 2010 at 11:42:41 pm
Camera needs to be in Film Mode too.
Steve Eisen
Eisen Video Productions
Vice President
Chicago Final Cut Pro Users Group
Shane Ross
on Mar 7, 2010 at 4:40:02 am
You can convert 720p60 to 30fps or 24fps later. You can use the DVCPRO HD Frame Rate Converter (in the TOOLS menu), or modify the clip...called CONFORM...using Cinema Tools, to whatever speed you want. Duplicate the clip first if you want one at normal speed, because CONFORM modifies the clip permanently.
Shane
