Dumping P2
COW Forums : Panasonic Cameras
Tommie Green
Dumping P2
on Feb 28, 2010 at 5:01:15 pm
Okay, I don't know where to go in this site to find my answer, but I trust you guys have heard this question thousands of times, so if you could just link/direct me, I'd be VERY grateful:
I JUST got my P2 card for my HVX. I was shooting a music video yesterday with it and ran out of space and needed to dump it. But out of like 10 people equipped with and 5 laptops (Macs and PCs), every form of FireWire cord and Yahoo/Google searches, NONE of us could figure out how to do it. So we just canceled the shoot and went home.
I edit on Adobe Premiere Pro CS4. My PC has no P2 slot OR FireWire port. HOW DO I DUMP THIS FOOTAGE? I don't even know what to look for? Is there a FireWire->USB adapter that exist? Is there a machine that dumps P2 cards for you? Do I have to download a program? Is there perhaps a website that goes over EVERY OPTION for dumping? I need to know SOMETHING by the end of the day because Day 2 is tomorrow and this card is still full...
Thank you SO MUCH for your help!
Richard Harrington
Re: Dumping P2
on Feb 28, 2010 at 5:24:56 pm
You can attach the camera to the computer to transfer.
Downlad drivers here.
Richard M. Harrington, PMP
Author: Video Made on a Mac, Photoshop for Video, Understanding Adobe Photoshop, Final Cut Studio On the Spot and ATS:iWork
Richard Harrington
Re: Dumping P2
on Feb 28, 2010 at 5:25:20 pm
Downlad drivers though https://eww.pavc.panasonic.co.jp/pro-av/support/desk/e/download.htm
Tommie Green
Re: Dumping P2
on Feb 28, 2010 at 5:51:05 pm
how do I attach cam to the computer if my comp has no firewire port?
Emre Tufekci S.O.A.
Re: Dumping P2
on Feb 28, 2010 at 6:31:46 pm
You can use the USB port on your computer. Here is a link to a previous thread where I had referenced the pages in the HVX manual where it shows you how to do it step by step.
Hope it helps
http://forums.creativecow.net/thread/193/879129
Emre Tufekci
http://www.productionpit.com
Tommie Green
Re: Dumping P2
on Feb 28, 2010 at 6:44:59 pm
@Richard Harrington and @Emre Tufekci, thank you so much! I'm going to look into it and get back at you
Richard Harrington
Re: Dumping P2
on Feb 28, 2010 at 6:39:57 pm
The FW port is for DV only.. there is USB on the camera as well... look harder
Tommie Green
Re: Dumping P2
on Feb 28, 2010 at 7:13:20 pm
I see the USB port, but is there a cord that can import the MXF files straight from the HVX to the USB on my comp?
John Fishback
Re: Dumping P2
on Feb 28, 2010 at 9:22:46 pm
I'm not familiar with Premiere's workflow, but with Final cut you should make a folder for each card you transfer, then copy the Contents folder and the Lastclip file into that folder. I don't know the HVX well and have always off-loaded P2 cards with a Duel Adaptor and MacBook Pro, but the cable will have standard USB ends. Perhaps a-type on one end and b-type at the other. Just check the manual, it's there.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24" TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.1, Motion 4.0.1, Comp 3.5.1, DVDSP 4.2.2, Color 1.5.1)
Shane Ross
Re: Dumping P2
on Mar 1, 2010 at 2:26:36 am
[Tommie Green] "is there a cord that can import the MXF files straight from the HVX to the USB on my comp?"
Yes...it is called a USB cable. Mini to full sized. The camera doesn't come with one, you need to go get one.
Shane
Tommie Green
Re: Dumping P2
on May 28, 2010 at 10:56:27 am
Oh, I figured it out that day by going to Best Buy and buying one of those Octopus like converters that have ALL options at the end. The USB worked. Then I had to find out the hard way downloading drivers was necessary before a connection could be made. Bunch bull****, but I got it done, than guys!
Shelley Roby
Re: Dumping P2
on May 26, 2010 at 7:51:28 pm
I am having the exact same problems transferring footage from our HPX500 to our p2 storage devices. We have both a panasonic and the nexto devices and the cameras and devices don't seem to connect. Did you ever resolve your dumping issues.
Thanks in advance.
