Card reader & drive on same bus...
COW Forums : Panasonic Cameras
Paul Turlick
on Feb 19, 2010 at 8:30:37 pm
Hi all-
Searched but didn't see anything. Is it possible (although probably not recommended) to have a card reader (AJ-PCD20) connected via usb and also the drive you are writing to connected via usb as well? It would be on a MacBook Pro.
Thought I had heard something about that not being a good workflow.
TIA-
Paul
Jeremy Garchow
Re: Card reader & drive on same bus...
on Feb 19, 2010 at 8:40:08 pm
[Paul Turlick] "It would be on a MacBook Pro. "
Same bus is okay. Loop through wouldn't be so good. Why not fw800 to PCD20 and usb to drive?
Jeremy
Paul Turlick
on Feb 19, 2010 at 9:56:19 pm
will do that but was just clarifying whether the other scenario would work if it came up.....
thanks Jeremy.
