Transfering a clip to a P2 Card
COW Forums : Panasonic Cameras
Pascal Greuter
on Feb 10, 2010 at 2:02:20 pm
Hello
I'm looking for a workflow, to export motion graphics (i.e. a rendered composition from after effects) to a P2 card.
The reason behind this is the following:
I'm a graphic designer working for a tv station. To play back the opening sequence we have a P2 player. It would be very easy when I can copy all my graphics to the p2 card and they can play it back during the show.
Any help would be appreciated!
Regards, Pascal
Pascal Greuter
Re: Transfering a clip to a P2 Card
on Feb 10, 2010 at 4:24:04 pm
I've found a solution.
With Premiere CS4, I can export a timeline to a P2 card. Works very well!
Cheers!
Pascal
Jeremy Garchow
on Feb 10, 2010 at 6:22:00 pm
MXF4mac is working on a P2 Export function that will export your FCP timeline to a P2 Card as well.
http://mxf4mac.com/mxf-p2-export
Jeremy
John Fishback
on Feb 10, 2010 at 8:19:28 pm
While I've never tried doing it, I believe Raylight will write to P2 cards.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24" TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.1, Motion 4.0.1, Comp 3.5.1, DVDSP 4.2.2, Color 1.5.1)
David Keslick
on Feb 11, 2010 at 5:46:37 pm
That is correct John. Raylight for Mac can convert your project to P2 structure or write it directly to a P2 card.
Raylight Mac
Dave Keslick
DVFilm.com
