New P2 cards work with older HVX200?
COW Forums : Panasonic Cameras
Rory MacNish
on Jan 20, 2010 at 5:57:06 pm
I'm looking to buy more P2 cards for my HVX200. I have 3 4gig cards and they work great. I want to buy larger cards, 32gig or 64gig cards. Will they work on my older HVX200? And, What is the process to upgrade the software to the camera to make it work.
Rory
Dan Brockett
Re: New P2 cards work with older HVX200?
on Jan 20, 2010 at 7:13:34 pm
Your camera will probably require a firmware update to work with the larger cards. Read the directions carefully, if you do something stupid, you can mess up your camera.
https://eww.pavc.panasonic.co.jp/pro-av/support/desk/e/p2ecard.htm
Dan
Providing value added material to all of your favorite DVDs
Rory MacNish
on Jan 20, 2010 at 10:17:28 pm
Thanks Dan, I will be careful.
Rory
Rory MacNish
Cornell Cooperative Extension
Multimedia
Southold NY 11971
Tracy Peterson
on Jan 21, 2010 at 12:55:19 am
The only thing you need is an older SD card to plug into the camera, with the firmware on it. Again follow the instructions and you should be fine. The bigger cards should all work fine on all cameras with the P2 logo.
Tracy Peterson
http://www.onetwomany.com
Dan Brockett
on Jan 21, 2010 at 2:03:32 am
Just make sure that your camera never loses power when doing a firmware update, you could regret it. A fully charged battery is safer than AC power because occasionally, the power browns out or blacks out.
Dan
Rory MacNish
on Jan 21, 2010 at 2:49:31 am
I have gone to the site with the firmware, I see they have a pdf, so I'll read the instructions carefully. I want to get two 64 gig cards. One more question: Will the old cards still work after the upgrade?
Rory
Rory MacNish
Multimedia Specialist
Riverhead NY 11901
Dave Neyman
on Jan 21, 2010 at 3:34:29 am
Old cards will work fine. I just did the firmware upgrade because I bought 2 new 32 GB cards. Evrything works flawlessly. As previously stated, follow the instructions to a T.
Rory MacNish
on Jan 21, 2010 at 4:28:38 am
Ok thanks
Rory MacNish
Riverhead NY 11901
Rory MacNish
on Jan 21, 2010 at 4:47:38 pm
Thanks to all, I just did the upgrade and it went fine. I haven't got the new cards yet, but can't wait to start shooting with 2 hours of HD.
Rory
Rory MacNish
Riverhead NY 11901
Bill Nelson
on Mar 4, 2011 at 8:20:27 pm
Is it possible to accomplish the firmware upgrade on a Mac?
Rory MacNish
on Mar 4, 2011 at 9:03:35 pm
Hey Bill, At the time of my upgrade, I only had Macs so that's what I used.
Rory
Rory MacNish
Marine Program
Riverhead NY 11901
We are working for you!
Tracy Peterson
on Mar 6, 2011 at 1:53:44 am
As he says below, the process is the same for Mac. It's more about the SD card file structure than what computer you do it on. As long as the firmware image is in the right directory in the SD card, you are all ready to go.
Tracy Peterson
