FCP problem ingesting P2 720p VFR footage
COW Forums : Panasonic Cameras
Kenny Reff
on Dec 22, 2009 at 5:20:24 pm
Hi all. I can't ingest into FCP v6 P2 footage that was shot on the HPX300 with DVC Pro HD 60P codec at 720p VFR on at 30fps or 24fps. I get an exclamation point for any footage shot at variable frame rates like 30 or 24.
I have NO problem ingesting 720p 60p footage that is shot WITHOUT VFR. I also have NO problem ingesting footage shot at 24PN or 30PN, even with VFR on.
I am using a Kona LH card with the latest v7.1 drivers, Mac OS 10.5.8, and Quicktime 7.6.4. A solution would be greatly appreciated! Thanks all.
Kenny Reff & Limelight Communications
Creative and Effective Digital Video
In the National Capital area:
Local: 703-242-4596
http://www.LimelightDC.com
Shane Ross
Re: FCP problem ingesting P2 720p VFR footage
on Dec 23, 2009 at 7:19:26 pm
WHy are you using a Kona card instead of importing the footage via LOG AND TRANSFER?
Shane
Kenny Reff
on Dec 23, 2009 at 8:17:35 pm
Actually, I am using Log and Transfer. I just listed the Kona card as added information. I can ingest all other formats except this.
Local: 703-242-4596
Shane Ross
on Dec 24, 2009 at 4:36:34 pm
in the P2 Import window...in the P2 Browser, there is a little sprocket drop down menu. Click on that and choose PREFERENCES. Uncheck REMOVE PULLDOWN and then try importing again.
Shane
Kenny Reff
on Dec 24, 2009 at 7:58:00 pm
Your right on. Thanks so much for spending your time helping me out. Much appreciated.
Local: 703-242-4596
