P2 Formatter
COW Forums : Panasonic Cameras
Paul Turlick
P2 Formatter
on Dec 8, 2009 at 6:31:53 pm
Hi-
Downloaded P2 Formatter (for Mac) from the Panasonic site. Installed the driver for the AJ-PCD20 and then downloaded P2 Formatter. When I insert a P2 card it shows up on the desktop but is not recognized by the formatter software. I've tried some re-installing etc but no luck.
The only thing I could think of (which is probably not right) is if there's a problem because the card is a Fuji E series. BTW- it's a 64 GB card.
Thanks-
Paul
Jeremy Garchow
Re: P2 Formatter
on Dec 8, 2009 at 8:03:16 pm
[Paul Turlick] "
The only thing I could think of (which is probably not right) is if there's a problem because the card is a Fuji E series. BTW- it's a 64 GB card."
Yes, that's right. You also have to update the firmware on the PCD20, PC only though. I use Parallels on a Mac to do the updating, but you will need to buy it and a copy of Windows.
Jeremy
Arthur Aldrich
Re: P2 Formatter
on Dec 9, 2009 at 12:38:24 am
Keep in mind that the P2 Formatter only works on Firewire.
I doubt that it is a firmware issue, otherwise the card would not mount on the desktop. I suspect that you are using USB perhaps to connect?
Art Aldrich
OTEK TV
Leader, NJFCPUG
http://www.njfcpug.org
http://www.otek.tv
Jeremy Garchow
Re: P2 Formatter
on Dec 9, 2009 at 3:35:51 pm
[Arthur Aldrich] "I doubt that it is a firmware issue,"
I'm pretty sure it is. Go to this page:
https://eww.pavc.panasonic.co.jp/pro-av/support/desk/e/update.htm#p2_mac
Check out the version that needs to be in the PCD20 in order for Eseries cards to work.
Then read this.
https://eww.pavc.panasonic.co.jp/pro-av/support/cs/csregistp2m/ep2main/soft...
I had to update my PCD20 with Parallels and Windows before I could get an E series P2 cards to work properly, even though they mounted ok.
Jeremy
Paul Turlick
Re: P2 Formatter
on Dec 15, 2009 at 6:10:37 pm
FYI- it seemed to be a USB v. FW as someone said. I tried with FW and it worked fine.
