35mm adapter
COW Forums : Panasonic Cameras
Gerret Warner
35mm adapter
on Nov 15, 2009 at 8:41:36 pm
I'm looking to rent a 35mm adapter for my HVX200. A friend said he used a Letus adapter, but so far I've come across a rental only for a P+K. Has anyone had experience with either. I'm hoping to find one that has minimal light loss, like a half stop and that I can put together with the camera without a rental house technician. Any help would be appreciated.
Noah Kadner
Re: 35mm adapter
on Nov 15, 2009 at 9:28:36 pm
It depends on the rig but I've yet to see one that doesn't lose at least a stop- that's just the nature of the optics on those things. I think the Letus is about the easiest to assemble. It's not exactly bolt on and go but it's definitely not something you need to be at a camera house to learn.
Noah
Check out my book: RED: The Ultimate Guide to Using the Revolutionary Camera! Unlock the secrets of 24p, HD and Final Cut Studio.
Call Box Training now featuring the Sony EX1 Guidebook, Panasonic HVX200, Canon EOS 5D Mark II, Canon 7D, and Panasonic DVX100.
Jeremy Garchow
Re: 35mm adapter
on Nov 16, 2009 at 9:28:37 pm
P+K, you mean P+S Technik?
Super nice, no image flip and the images are great. I would take your camera in to the rental house and have them put it on, though.
Jeremy
Gerret Warner
Re: 35mm adapter
on Nov 17, 2009 at 2:25:19 am
Thanks, both.
Yes, Jeremy, I meant the P+S Technik, which seems to be the best of the lot. But the rental house in Dallas where I'll be shooting has the Letus, says it's a half-stop of loss, is user mountable, and the price is right, so looks like what I'll try.
Thanks again for the advice.
Gerret
Jeff Regan
Re: 35mm adapter
on Nov 17, 2009 at 2:36:25 am
I own two Letus Ultimate 35mm adapters as well as the Letus B4 Pro 2/3" relay lens. I use the adapters on our HPX170, EX1 and HPX2700 and many other cameras belonging to clients. I have found that they are very sharp edge to edge, comparing favorably to the P+S Pro35.
I would say that light loss is closer to a full stop. If possible, it is best to have the rental house build the rig for you, do the back focus, and if using a 2/3" camera and relay lens, a white shading file needs to be done for the Letus system(as you would with a Pro35).
Jeff Regan
Shooting Star Video
http://www.ssv.com
Jeff Regan
Shooting Star Video
http://www.ssv.com
Gerret Warner
Re: 35mm adapter
on Nov 17, 2009 at 2:51:31 am
Thanks, Jeff. Yes, other friends have told me it's closer to a stop than a half stop, in spite of the specs and the rental house claims.
And thanks for the tip about helping building the rig. No need for white shading on a 1/3" CCD?
Jeff Regan
Re: 35mm adapter
on Nov 17, 2009 at 3:00:05 am
Haven't noticed white shading errors with 1/3" cameras as much as 2/3". Even if an issue, I don't know of any 1/3" cameras that offer manual or auto white shading anyway.
Make sure you run the ground glass speed at max, 99, if an Ultimate.
Don't use shutter speeds above 1/500th. Be very careful about dust on the various elements, including between the achromat and the adapter rear element.
Jeff Regan
Shooting Star Video
http://www.ssv.com
Jeff Regan
Shooting Star Video
http://www.ssv.com
Gerret Warner
Re: 35mm adapter
on Nov 17, 2009 at 12:38:37 pm
Thanks, Jeff. Very helpful details.
Gerret
