p2 cards
COW Forums : Panasonic Cameras
Robert Brown
p2 cards
on Nov 13, 2009 at 3:06:27 am
During a shoot a not so helpful person decided to unplug my MBP from the HVX 200 and unplug the EHD with out any concern for what was going on in the laptop. When he brought the laptop to me the screen was black I had to restart it to get the screen back up. I then started the download again in a different folder and it finished without a problem. Now when I try to find the file with log and transfer FCP 6.06 doesn't find them. If I search for them through add folder the content file is highlighted but the lasttext file is grayed out. Also they have the same date but different times one is 4:34pm and the lasttext is 10:05 pm which doesn't make sense because the computer was turned off at that time. Please help the I have a lot of shots that will be hard to replace.
Emre Tufekci S.O.A.
Re: p2 cards
on Nov 13, 2009 at 5:45:14 pm
If you cant get the FCP to read your card put it into After Effects to see if you can read the MXF Raw. From AE you can export the contetn using FCP codecs as if you had ingested through Log and Transfer.
Same can be done through Avid using AMA. Hope this helps.
Emre Tufekci
http://www.productionpit.com
