FS-100 playback on HPX300
COW Forums : Panasonic Cameras
Brian FitzGerald
on Nov 12, 2009 at 1:42:29 am
I looked all over for this but could not find an entry...
I just moved up to the HPX300 from the HVX200. One of the reasons I did this is so I could continue to use my FS-100. (Yes, I know it only works for DVCProHD...) They seem to work fine together but I cannot figure how to play the FS-100 back through the camera LCD like I could on the HVX200. There is no button that pops it into the "receive" mode.
What is the procedure, please?
(By the way, my neighbor has a business that sells PERFECT firewire cables with "L" plugs that fit perfectly between my FS-100 mounted behind the 300's handle down to the 1394 port on the back of the camera - usbfirewire.com - they took a picture of my setup for their website if you want to see how I did it. It is very clean.)
Brian FitzGerald
FitzVideo.com
Steve Eisen
Re: FS-100 playback on HPX300
on Nov 12, 2009 at 2:41:10 pm
Brian
Put your camera in MCR mode and press the Thumbnail button.
Check your 1394 settings on the camera.
Steve Eisen
Eisen Video Productions
Board of Directors
Chicago Final Cut Pro Users Group
