48frame slo-motion to real life speed
COW Forums : Panasonic Cameras
Joel Guy
on Oct 25, 2009 at 7:40:32 pm
I shot a ton of surf footage in slo-motion (720p/24pn and cranked the FRAME RATE to 48) on a P2.
Now I was hopping to show/edit some of the clips in "normal life" speed. When I change "speed" to 200% it seems to cloud the image and create a jerky motion to it. Am I missing a step in the conversion to "real life speed"?
Jeremy Garchow
Re: 48frame slo-motion to real life speed
on Oct 26, 2009 at 3:51:15 am
Turn off frame blending when the speed options come up.
Joel Guy
on Oct 26, 2009 at 11:44:07 pm
Thank you, it looks much better. Joel
Jeremy Garchow
on Oct 27, 2009 at 2:53:29 pm
Cool. You understand the reasoning behind it?
Jeremy
Joel Guy
on Oct 27, 2009 at 5:24:17 pm
Turning off frame blend seems to make sense as it seems there is no need to blend frames in this situation... there are plenty frames..
Seems like if you were slowing down 24 frame it would have to "blend" to "create" a frame every other frame
..am I on the right track?
Jeremy Garchow
on Oct 27, 2009 at 6:58:59 pm
You understand perfectly. Have fun with your project.
Jeremy
