slow motion question
COW Forums : Panasonic Cameras
michael klein
on Oct 11, 2009 at 2:42:16 am
hi everybody,
shot 720/24p (NOT pn) and set the frame rate at 48fps.
how do i get it to play slow motion in fcp?
is there a special way it needs to be transfered?
please let me know.
thanks.
mike.
cowcowcowcowcow
Jeremy Garchow
Re: slow motion question
on Oct 11, 2009 at 12:38:04 pm
Couple of ways. When importing make sure the remove redundant frames option is checked in the L&T prefs.
Or use the DVCPro HD frame rate converter in the Tools menu. The remove redundant frames option should be unchecked if you go that route.
michael klein
on Oct 11, 2009 at 6:41:10 pm
L&T didnt work, but the dvcprohd converter did the job.
thank you!
