Compatibility question: Panasonic AJ-PCD10 + MacBook Pro + Dual G5 tower
COW Forums : Panasonic Cameras
Doug Haight
on Oct 8, 2009 at 3:26:26 pm
Camera: Panasonic HPX170
Computer: MacBook Pro, 10.5.8 in field, Dual G5 1.67 for FCP editor
Current P2 transfer method: Duel adapter to MBP via ShotPut for verification and transfer to two separate external drives
Duel adapter is workable but finicky and doesn't work with G5 editor.
I am looking to buy a Panasonic AJ-PCD10 for use with both MBP and G5. I am getting lots of varying reports about success with either/both. Assuming I have all the correct drivers in place and stay away from OS X 10.6, has ANYONE had success with the AJ-PCD20 and MBP & G5? Can you give me any tips on making this work consistently?
Amazing how I can't get a straight answer to this, on the Panasonic site, here or elsewhere. Any help?
Doug H
Jeremy Garchow
Re: Compatibility question: Panasonic AJ-PCD10 + MacBook Pro + Dual G5 tower
on Oct 8, 2009 at 7:43:56 pm
PCD10 or 20? You mention both.
PCD20 Should work.
Jeremy
Doug Haight
on Oct 8, 2009 at 11:20:03 pm
Oops. Yes I am looking to buy the Panasonic AJ-PCD10. Will that work with my hardware?
Doug H
Jeremy Garchow
on Oct 9, 2009 at 6:28:05 pm
I believe the PCD10 is windows only.
Samuel Small
on Jun 16, 2012 at 6:04:05 pm
Yes Panasonic AJ-PCD10 is windows only.
Has anyone tried mounting it to a mac that is running windows OS via bootcamp?
